One-Pipe steam system
![[Deleted User]](https://secure.gravatar.com/avatar/491a640c2446f73ae42b6c1cfd784ac2/?default=https%3A%2F%2Fvanillicon.com%2Fc303e82081129e4e07fec3b2cb2ceded_200.png&rating=g&size=200)
[Deleted User]
I have a 500 square foot one-pipe steam system. Some of the horizontal pipes have corroded. When these pipes were replaced a good amount of mud came out. What steps do I need to take (and what products should I use) to clean out the system as best I can.
cleaning the boiler
clean the boiler on the top of the waterline, and at the bottom. this procedure is described in greater detail than i can type in dan's book, "the lost art of steam heating",available on this site, and you need it to become better informed as a steam user!
the process is called "skimming" which is the controlled draining of surface contamnnts, from an elevated waterline inside the boiler, through a port made for that purpose. hopefully your boiler was installed by a professional steam pro, who would have made such a skimming port, and left it lightly capped,waiting for this very occasion! --nbc0 -
cleaning the boiler
check your boiler installation manual about skimming and chemicals. for instance, peerless suggests using arm & hammer washing soda, but other makers will not suggest chemicals for cleaning. in any event these products are flushed out in the end leaving pure water. i would suggest no chemicals for an ongoing basis, except to take care of PH problems.--nbc0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
