Celtic Hydrothem Replacement
pst
Member Posts: 2
I have a wall-hung Celtic Hydrotherm in a closet venting into the chimney. It seems the heat exchanger may have gone bad and need to have the whole unit replaced. What unit can I replace this with? I need to have a wall-hung venting into the chimney. I can not use a direct vent since the closet is not on an outside wall. I need it to be a wall-hung, I am confined with space.
Please assist me in recommending a replacement unit, I have not been able to find one that meets the above requirements.
Celtic parts
Use Google.... www.celticparts.com0 -
You can still use a sealed combustion unit if you are not on an out side wall. As long as you are within venting distance from the outside wall. or the roof. The best unit to replace it with is the one that your licensed installer has the repair parts availible for and they are well versed in installing.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
