radiant and steam
nicholas bonham-carter
Member Posts: 8,578
yes it is possible; but you need the good book--"the lost art of steam heating" by the prophet of steam--dan holahan, founder and keeper of this site,available in the online store.
there is a whole chapter on this very subject. also it contains all the information you need to keep the rest of your steam system in good condition!--nbc
I would like to know what your thoughts are on adding a loop of radiant off of a steam boiler? Any certain pipin diagrams i should follow do i need a flat plate heat exchanger. Do i need a bronze pump on the boiler side if i use a flat plate.0
- 86.2K THE MAIN WALL
- 52 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 99 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 913 Plumbing
- 6K Radiant Heating
- 380 Solar
- 14.8K Strictly Steam
- 53 Water Quality
- 41 Industry Classes
