tekmar with wilo
MIke_Jonas
Member Posts: 209
The squiggly line represents "phase".
as in 1 phase, 230 volt.
At least, that's always been my take on it.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=572&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
tekmar with wilo
I am installing a tekmar 420 control with a wilo stratos as the distribution pump. The control contacts puts out 110 volt but the circulator needs to receive 230 volts. Can anyone suggest a relay that will make this happen.0 -
relay
you can get relays with 110v coils, try releco or omron, I believe tekmar also offer one in their catalog.0 -
Please contact me via e-mail
I have a few options for you.
Mark H
110v
come to think of it, they do say "1~230v" on the rating plate, so I would think 110 would be ok, best to get it from the horses mouth though.0 -
Yep
The Wilo Stratos is 230 volt, single phase.
Mark H0 -
Hi Boon
made by RIB Small relays in any configuration you want.
24 to 240 vac.
Al0
- 86.2K THE MAIN WALL
- 52 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 99 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 913 Plumbing
- 6K Radiant Heating
- 380 Solar
- 14.8K Strictly Steam
- 53 Water Quality
- 41 Industry Classes
