Gauges going bad
realolman
Member Posts: 513
I meant that it was a 3-1/2" pipe.
The pressure on it is 18 OSI
gauges going bad natural gas train
In the past 2 weeks I have replaced the gauges marked with an x in the attatchment 3 times. the last time,this morning, I upsized them from a 0 to 30 osi to a 0- 60 osi.
I just looked at them about an hour ago after 4 hr service and see that the 0- 60 are reading about 5 osi when there is 0 osi. The one in the middle does not pop.
If the picture looks crappy click on it... it'll look a little better.
What could be causing this... or more to the point... what can I do to get it to stop... We couldn't find liquid filled in 0-30 osi... I don't know about 0-600 -
As I am sure you are already aware,gas pressure,residential 4inches water column,commercial 12 inches and higher,creates an unusual strain on very sensitive gauges,I recommend using a diagnostic magnehelic or digital sensor.These service level instruments are more robust.May I ask why you are continuosly monitoring your gas pressure?Are you concerned about input,demand,or distribution?Lyle from Lisle(HVACMD)0 -
Lyle
I thought heat engineering was in Hinsdale?There was an error rendering this rich post.
pressure
Are you sure you have all of your units of measure correct? You show 3 1/2" after the double block gas valve, I assume that's water column? 60 osi = 3.75psi , 3 1/2" = 2osi. I would remove the first gauge after the main valve and replace it with a tatle-tail gauge of around 5psi and see what the max pressure is. You don't show the reg if there is one ahead of the main valves. You may have a main reg that is not locking up and allowing street pressure to hit the gauges. Test don't guess.There was an error rendering this rich post.
I guess
there is no real reason to have the gauges on line all the time. I thought about putting valves on them. That may be what I have to do.
It is an industrial facility.
There are two regulators ahead of the main valves that drop the pressure down to 18 OSI. I can't see why two gauges pop, but the one in between them does not.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
