Steam Supply
Eileen Olive
Member Posts: 99
Has anyone come across steam supply run in copper? This appears to be a 4" copper supply running up 4 floors. It just seems rather odd, to say the least.
oversized
A 4 " steam riser for a four storey bldg. sounds slightly oversized. maybe its a soil stack.0 -
there are several posts here on that subject
http://forums.invision.net/Thread.cfm?CFApp=2&&Message_ID=111848&_#Message111848
apparently the copper pipe mfgs. promoted the use of copper pipe for a while in the 60's.
no one here approves off it,except on the return under the waterline.-nbc
Yes, we agree, but it is there a 4" copper steam supply line in a college here in NYC. Now they want us to cut it and braze a tee into it for a supp;y for an air handler. We just thought it rather unusual.0 -
braz-o-let
drill it & use a braz-o-let boss. or if you have access to a T-DRILL . less work for mother !!0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
