2 Pipe Vacuum Return
Big Ed_4
Big Ed_4 Member Posts: 3,102
Can you post a system diagram ? I know it will help us help you ...
  • matt_63
    matt_63 Member Posts: 10
    If an accumulator tank (with no pumps) is used in a vacuum return system should the tank be under a vacuum. The vacuum tank/pumps is pulling condensate return up from the accumulator tank. The vacuum gauge on the vacuum tank reads 10"hg. The air vent on the accumulator tanks is blowing air out. The vacuum pumps run constantly and when they are shut off the vacuum drops to 0 within seconds. Is my accumulator tank piped incorrectly?
  • If you are referring
    to the hurling water tank; the vacuum pump uses water in the tank for lubrication & vents the air, pulled from the system, out the vent on the hurling water tank.
    Most systems, we work with, operate in the 3 to 8" vacuum range. Sounds like a big pump on a system w/ many leaks.
  • matt_63
    2 pipe vacuum return
    Attached is a photo
  • Check page 192
    of "The Lost Art of Steam Heating". Your setup is shown and described there.
