\"Concrete-like\" Soot
Bill_110
Member Posts: 52
Could it have been some sort of leak plugging goop, the kind which the manufacturers say never to use.
Strange....
I was called to clean an old New Yorker steel boiler (hot water) and found it totally plugged...CO alarms going off and the like.
I've had plugged boilers before but nothing like this. The bottom two inches of the tubes were completely solid with a grey/tan substance. I had to actually drill out the stuff with a paddle bit on the end of an electrician's extension...
Any idea what this substance was or what caused it (besides neglect )?
Thanks,
Mike0 -
Soot
Sulfur? And neglect.0 -
Does the heat exchanger have very small water leaks ?
Or alot of condensation? contaminated make up air?0 -
Everything looked dry in, on, and around the boiler...
can i still get an accurate draft reading with some of the tubes still containing the crud?0 -
check your stack temp, it probably is very low; causing condensation which when mixed with lack of maintenance makes cement. when you re-test make sure you are at the minimum firing rate or better.0 -
Thanks! I have it scheduled to recheck the boiler this week.
We shall see!
Did customer turn off boiler during summer? Happens a lot, they don't use for hot water so they turn off in summer. Boiler sits in nice cool, damp basement and the thing sweats like a cold beer in the hot summer sun. I always suggest the customer keep a low temp in boiler all year to help prevent this.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
