T-Stats, dual sensor
rjm
rjm Member Posts: 60
honeywell pro8000 can be wired for up to 9 sensors. Reasonable price too
  • wof
    wof Member Posts: 2
    T-stats, dual sensor
    I'm looking for a thermostat that accepts 2 sensors (both indoor). Each sensor to be located in each of 2 one-floor apartments with the thermostat in basement. These are rental units. White-Rodgers used to make a 90 series that did this with sensor averaging and a stat-disabling function, but no longer does. Anyone have insight into this type of stat/sensor combo?
    Thanks in advance.
  • clammy
    clammy Member Posts: 3,156
    white rodger
    Wof ,white rodgers still does make this stat except it will take up to 3 sensors and do averaging i have used them and have had excellent results ,i can't seem to find the model # except i know it's still made peace and good luck clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
  • wof
    wof Member Posts: 2
    Clammy,
    If you're referring to this stat and related sensors, it doesn't seem to be made anymore. Please let me know if you have different info.
    http://www.white-rodgers.com/wrdhom/pdfs/06_Cat_pages/Cat_06_pg0010_11.pdf
  • clammy
    yes
    Wof i believe it was a 90 series and i believe there still avaiable check out either abco supply or united refregeration they still may be in stock ,i recently install one about 6 months ago i hope it is not gone it's a great product that cheaply solves alot of promblems instead of spending alot more on some thing else which 1/2 of the opionts are not used
    NJ Master HVAC Lic.
    Mahwah, NJ
