Copper or black pipe for rooftop solar?
Brad White_191
Member Posts: 252
copper, not that I have nearly as much experience as others in this forum. But given issues of glycol, the fewer mechanical joints the better.
The "exposed to weather" issues may cancel out because the lines are covered, but if you had a void in the insulation, how would you know that you had an external rusting problem? Or leaks at the screwed joints for that matter?
For those reasons, I would go soldered copper, or brazed if I was so skilled.
Now, copper is still more than iron but both metals have come down a good bit recently. As much as a third that I have seen. And, you are going to do any install once.
My $0.02
Brad
My $0.02
Brad
Copper pipe or black for piping solar?
Is is ok to use black pipe to pipe up solar panels? Price and strength being main reasons0 -
The
solar "linesets" seem like the best way to go.CSST tubing,control wire and insulation all in one
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"To learn more about this professional, click here to visit their ad in Find A Contractor.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
