Radiator Air Vents
Oakvu
Member Posts: 26
My vents have to be the 1/8" size. They're no where close to a 1/2" on the outside. Closer to 3/8" on the outside and they're all angled vents. Thanks.
Radiator Air Vents
I am looking to replace my radiator vents with Gortons. There are 2 connection sizes available, 1/8" and 1/4". Where do I take the measurement to determine which size to order? I measured the connection on one of my existing vents and it may be just a bit larger than 1/4", almost 3/8". Are the only 2 radiator sizes 1/8" & 1/4"?0 -
Those are NOMINAL pipe sizes, based very roughly on inside diameter. 1/8" pipe actually measures .405" on the outside diameter, just over 3/8". Most radiators I've seen take 1/8" NPT vents . . . at least the ones with 90 degree angle vents. 1/4" pipe actually measures over 1/2" on the outside. Most 1/4" vents have straight connectors and are for convectors, not the more typical radiators.0
- 86.2K THE MAIN WALL
- 52 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 99 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 913 Plumbing
- 6K Radiant Heating
- 380 Solar
- 14.8K Strictly Steam
- 53 Water Quality
- 41 Industry Classes
