Gravity generated water pressure?
David Nadle
Member Posts: 624
How were they going to fill the tank?
Sent to me by a friend...
I get the most interesting questions thrown at me...Can anybody answer?
"If you have a 1500 gallon tank and want to create 50 lbs of inlet pressure to a plumbing system, how high above the point of use does the tank have to be assuming 3/4 inch supply line? How much does the pressure drop with lowering of the amount in the tank?
I found a water supplier who will deliver to me out on the property and will deliver up to 1600 gallons at a time. The floor of the trailer is 24" off the ground and the sink is 24" above that. The shower head is 72" inches above floor level or 8 feet above the ground level. How much gravity pressure does it take to deliver water 8 feet above ground level?"0 -
Pressure
2.31' of elevation= 1psiThere was an error rendering this rich post.
You know something?
I knew that! Duh... LOL!!
I don'tthink they're going to like the answer though.0 -
Why not just use a pressure booster?0 -
.433 psi per ft of water column
Makes no difference what diameter of pipe or storage tank. So to get 50 psi, your water level has to be 50/.433 or 115.48 ft above the point of delivery (faucet).0 -
yup,
someone else came up with 115 ft too. I came up with 123.5 using 2.31 but then I figure in an extra 8' for the level of the shower nozzle. Same difference when your tank needs to be over 100 feet high. LOL...
I guess this is for a hunting cabin in the woods. Plenty of trees but none of them have outlets for some reason.
That's an old joke for the girls, "Can we bring our hair driers?" "Sure, long as you can find a tree with an outlet to plug them into."0 -
Say,,,
that's a good question! I'll have to ask.
Or better yet, read the third sentence of the question again. I assume the water supplier will have a pump? Maybe not though. There'll be a big surprise in store if the supplier relies on gravity to empty the truck.
The discussion has turned to 12v RV pumps BTW, seems 100 ft high tanks are a bit of a snag in the plan.
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
