oil burner runs on empty
Hollis
Member Posts: 105
I have two oil tanks and was switching one over and the big dummy forgot to turn the the other one on. So in a while the oil burner was running dry, I didn't notice for a while but it started up w/o repriming and I didn't think much more about it until later. Should it have shut down? (cad cell?) When there was no flame?
From what you are saying, it sure sounds like it should have shut down. sometimes valves don't close as much as you think they do. Are it sure there was no flame?
Probably a good idea to have it checked out.
The last time
fire continued to burn without having apparently enough oil (for eight days in fact), was well over 2,000 years ago.
Time for celebration, I would say
scary stuff
I've seen about three cadcell failure in my travel and they were not good.
Two were on system that lost the transformer.
One was on a big boiler at a church with a steel firebox that held about 200 gallon of oil before the pastor turn off the burner switch.
Another was on a home with a downflow oil furnace and all the oil ran down into the duct work under the house.
Its a good thing they only had a 250 gallon tank.
You really should have it check.
