Flushing the Boiler
kpc_44
kpc_44 Member Posts: 29
should be flushed out every week to 10 days during the heating season if it has a float type low water water cutoff. If this is not done the LWCO could stick and dry fire the boiler. How much water are you flushing through? 3+ gallons would not be out of the question. Steam is an open system... it will get dirty at times. When you changed out the boiler was it flushed and skimmed?
  • FJL
    FJL Member Posts: 354
    Dirty Water
    At the start of the heating season, I had my heating contractor come out to clean the boiler, and the water in the water gauge was clear at that was done.
    Then, about one month later, I went to flush the boiler, as my contractor said I should do every week or two. The water I flushed was very dirty and did not run clear, although it did get less muddy. Not wanting to run it so long that I'd empty a giant amount of water, I stopped flushing. The water gauge was brown, but I hoped it might settle, as it did after the contractor had come out to clean it.
    I went down yesterday (a week later), and the water in the gauge was still brown. So I flushed it again, and could not get it to run clear, although it did get less dirty. Water in the gauge was still muddy.
    I don't understand why the water guage would be clear after it was cleaned, and before I flushed it, and stay muddy after I flushed it.
    Boiler was installed in Summer of 2007.
    Thanks.
  • Rob Blair
    Rob Blair Member Posts: 227
    What kind of boiler?
    We need some details, steam Hot water? Cast iron. Mod condensing.
    I know nothing about steam, but never heard of flushing it every two weeks or years to that matter.
    Rob
  • FJL
    Sorry
    Gas fired, cast iron, steam boiler for one pipe steam system. Burham Independence model line. Boiler services a four-unit apt bldg.
  • FJL
    By changed out the boiler . . .
    do you mean when the new one was installed? I can't say for sure what the contractor did. I do know that he told me that his men had skimmed the boiler after it was installed, and it was skimmed and cleaned again before the heating season. I had noticed the water line jumping around a lot last season, so I had them come back and skim/clean before we started up this season.
    As I said, after the contractor skimmed/cleaned, the water gauge showed clear water, and the muddly water showed up after my first attempt to flush.
    I suppose 3+ gallons was what I had flushed. I can't say for sure how long I had the valve open to flush, but it was one, two, or three minutes, enough time for the boiler to refill with water while I was flushing. Water gauge showed boiler was less than half full and by the time I was done, it had fill almost to the top of the water gauge.
  • FJL
    Water Clear
    Water in the gauge is clear. I guess it just needed time to settle, and I must flush more than once a month.
  • Mark Custis
    Mark Custis Member Posts: 537
    Good Things
    come to those that persit.
