USE solar codebook revisions any suggestions?
Royboy
Member Posts: 223
of this codebook to know what's in there and what needs changing.
am I correct in guessing that you have to buy it to know? (or is it available online)
Roy
Sunrise Energy Services
Roy
Currently in input stage
the Uniform Solar Energy Codebook will be updated. IAMPO is asking for input. I'd be glad to pass along any suggestions. It will be 4 years before you have another chance to suggest changes.
I'd like to see the double walled HX requirement disappear
Maybe clear up the engineered stamped plans requirements, when it is needed or not.
Min.R-value for solar pipe insulation.
Any other?
hrBob "hot rod" Rohr
Living the hydronic dream0 -
Direct connection
I'd like to see direct CW connections to the solar fill prohibited, with manual fills allowed only.
I guess
lightning portection, or grounding since you say it's not currently listed.
Does the Uniform Solar Code include PV systems. And is the Uniform Solar code part od or referenced with any other code standards? UPC, etc
- 114 Geothermal
