taco wiring zone valves and circ
shawn laverty
Member Posts: 42
I have a existing oil fire boiler with 1 circulator running 2 zone valves. The existing boiler has a tankless that is gone and the Homeowner wants to install a 40 gallon superstor indirect heater. I know how to wire the system with all zone valves including the indirect tank using a taco 3 zone control with priority but i would rather run a circ on the storage tank loop. I am not sure if i just use a 2 zone switching relay for pumps and wire the indirect on priority and move the existing circ. (which is currently running to the c1 and c2 terminals on the aquastat) to the new relay box but im not sure what goes into the thermostat connection on that side seeing we are using zone valves. I mean does it just make sense to run a zone valve for the storage tank just not sure of the cons to this besides being slow opening any help i would appreciate.
Thanks shawn
Thanks shawn
Taco Has
a concise, all-products wiring guide. Much sought after, meaning that many heating contractors want to get copies for their electricians.I am not sure if it is on the Taco-HVAC.com web site, but they can direct you.
I have mine and you can't have it0 -
Thank you brad I appreciate it.0 -
Available online
You can download the whole enchilada...
http://www.taco-hvac.com/en/products/Switching Relays/products.html?current_category=139#
JMB0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
