Change radiant from electric hot water heater to hot water coil
Dennis Thacker
Member Posts: 2
I installed a radiant heating system using Dan's book " Hydronic Radiant Heating. It was very helpful. The system works great (except for the electric bill). I am currently replacing my oil furnace with a Coal fire warm air furnace with a hot water coil. I would like to feed the old electric hot water tank (radiant heat) as well as a separate electric water heater for my potable water. How do I plumb everything? Do I add a heat exchanger for the potable water. I could sure use some help. The PEX heating coil contains about 7 gal. The heating coil will supply about 200 gal. per hour. Thank you
Chg electric hot water heater to a hot water coil from a coal fu
I installed a radiant heating system using Dan's book " Hydronic Radiant Heating. It was very helpful. The system works great (except for the electric bill). I am currently replacing my oil furnace with a Coal fire warm air furnace with a hot water coil. I would like to feed the old electric hot water tank (radiant heat) as well as a separate electric water heater for my potable water. How do I plumb everything? Do I add a heat exchanger for the potable water. I could sure use some help. The PEX heating coil contains about 7 gal. The heating coil will supply about 200 gal. per hour. Thank you0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
