Underslab insulation for hydronic system in MN-Recomendations
Roger_10
Member Posts: 1
2 \" of Extruded
polystyrene... the blue Dow board. don't fall for the bubble foil or thin insulations joke that claim eqivalent R-value.
PS... make sure you get your perimeter insulated too.0 -
I still use,,,
Insultarp but explain the differences to my customer beforehand and give them the choice. I like it because it is a quicker, easier install and can be walked on without damaging it.0 -
R 7.2 per inch Polyisocyanurate foamboard with foil face. Its the highest R value with radiant barrier, use 2" The blue and pink board are R5"0 -
labor savings plus insulation
www.creatherm.com
save tube install labor, a jar of aspirin, plus get R9 insulation.0 -
no radiant...
barrier if the slab touches the insulation...
http://www.healthyheating.com/Page 55/Page_55_o_bldg_sys.htm
Not to mention if the poly iso gets wet you lose some of it R value... and ants love the taste of the stuff...0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
