cavitation heater
mike parnell
Member Posts: 42
has anyone seen or tried heating with a cavitation heater??check out hydrodynamics.com. going to give it a try,see what happens...mike
Curious to see how that works. I looked at the site and the concept makes sense. It just looks like they are not focusing on comfort heating as a use.0 -
Heat
Not likely, you would still get a less efficient transfer of energy then if you used an electric water heater. What you get is 3,413 BTU/ kW or 2445 BTU/Hp/H and no free lunch the pump would have losses asocated with it greater then a heater,0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 988 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
