energy kenetics
chapchap70_2
Member Posts: 147
Energy Kinetics has a website www.energykinetics.com where you can get the basic info on how the system is supposed to work.
The pressure vessel is designed to withstand a large negative pressure without significantly changing the flame. They do not recommend a barometric because it needlessly takes warmer air from the basement to reduce draft which can only be replaced by outside air coming through door/window cracks. They believe this wastes energy.
energy kenetics
Does anyone have a spec install sheet for the energy kenetics 2000 . This is natural draft and does not have a lwco , barometric draft regulator or any oil nozzle spec sheets to go by. Also the primary pump is pointed in a downward pumping direction. Any help is appreciatedMark Overly.0 -
They
don't come standard with a LWCO,you have to order it.Use whatever LWCO you use with any other boiler.They don't use a draft regulator at all.Burner specs are available at Beckett,Carlin and Riello websites.They come with an OEM burner already installed,so unless you want to change firing rate or there is a problem,you don't need specs
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
reply
thank you for response. This one is 7 years old, w/ no barometric. Why dont they use one? Also , I want to understand the function of the control as I noticedd in call for heat it seems to maintain a constant temp output.
Also the direction of pumpingMark Overly.0 -
reply
the website has just homeowner info in my opinion. Im interested in the install manual so I can properly check this thing . schematics ectMark Overly.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
