severe duty baseboard
Brad White_204
Member Posts: 20
it is a short piece and takes such abuse, I would use a commercial product such as Vulcan Linovector with a 14 Gauge cover. If spills are an issue, use a front outlet, not a top or sloped top outlet. And as Ron Jr. said, mounting it higher is a good idea. These start at 4" off the floor by the way.
Second choice, if length is an issue (but depth is not so much), is to use a convector, also with a heavy gauge cover.
I was asked to replace some cabinet on Slant-Fin series 30 baseboard in a local VFW Post. This baseboard is in the bar area, and gets beaten up pretty badly. I am considering replacing it with Slant-Fin's HD series, which has 16 gauge steel enclosure. I would like to know if anyone has used this, and how it holds up.0 -
By chance
This wouldn't a Levittown NY VFW ? We replaced a boiler a few years ago in one and they were asking about changing the baseboard near the bar .
I haven't used the HD series . But SOP for baseboard in high trafic areas for us is to mount it higher than usual to keep it from being banged into with shoes . 2 to 4 inches off the ground usually does the trick .0 -
I have had to
deal w/ this at a college frat... the ultimate in abuse situations. the ONLY thing that worked was cast iron baseboard.0
- 62 Biomass
- 114 Geothermal
