Big problem in a small boiler room
Steamhead (in transit)
Member Posts: 6,688
1. Hot water or steam system? Coil or no coil?
2. How did you come up with 180,000 BTUH? Unless you did a heat-loss calculation (on hot water) or radiation count (on steam), this figure might not be accurate. Who knows, you might be able to use a smaller boiler. Many currently installed boilers are way oversized.
I've never installed one, but the Moscone boiler with the burner on top might be a good fit here.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
I have a job with a leaking WM 568. The owner wants the highest effiency replacement he can get. The problem is I only have five feet to work with. No way any of these tripple pass boilers will fit. I need 180,000 BTU. And I am not certified for any of the condensing oil fired units. Any Ideas Welcome......0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
