Remove condensate pump?
ChasMan
Member Posts: 474
In another thread, Steamhead (I think) said that condensate pumps are often employed unnecessarily in steam systems. If the piping arrangement is such that a pump isn't needed to return condensate to the boiler, is there some other benefit/rationale for having one? Seems like it's just another item to fail.
Thanks,
Patrick
Thanks,
Patrick
If Gravity was good enough for Sir Isaac Newton....
it is good enough for me
Seriously, if gravity works, I would not mess with it. It is The Law.
When you need to move condensate to a different elevation than gravity allows, you need a condensate pump.
If your boiler has low water content compared to system demand, you need a condensate pump, except in that case, it would really be called a "Surge Tank" or a "Boiler Feed Unit".
As you suggest, if it is not needed it becomes a potential liability over time.0 -
Gotcha.
Thanks!
Patrick0
