Coloring Antifreeze
b young_2
Member Posts: 7
We use glycol antifreeze that 100% pure and is very clear. I am looking for a way to add color to the antifeeze so I can tell when a each loop is full. It is not a big deal but it is nice when adding it to a existing system. When the red comes that circuit is full. Is food coloring okay or is there something else out there.
food coloring...
is fine.0 -
I just installed a closed loop solar hot water system and used Cryo-Tek I purchased from a local supply house. It was red in color. I had to buy 5 gallons. I needed 1 more gallon to fill the system copletely and went to Home Depot and bought a gallon. It was blue. I E-Mailed the Cryo-Tek Company and it was OK to mix the 2 colors. Have a gret day!!!!0 -
Be careful with solar fluid choices
especially with evac tubes which can reach very high temperatures. Look for a "HD" fluid with the high temperature range.
I think Hercules recommends against Cyro-tek for solar use? Keep an eye on the ph of that fluid for signs of breakdown./
hrBob "hot rod" Rohr
Living the hydronic dream0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 975 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
