insulative value of soot?
Maybe this will help
Ed Carey
  • Mark_122
    Mark_122 Member Posts: 5
    I have seen it written that soot on heat exchangers really insulate heat transfer to the water/steam.(with how important to brush these down) Anyone have any information on this? R value of say 1/32 inch of soot?
  • Soot
    Ed Carey
  • Soot
    See the attached article from the US Department of Energy
    Hope this helps
    From Ed Carey
  • Mark_122
    THANK YOU ED!!!! Exactly want I wanted!
  • Norm Harvey
    Norm Harvey Member Posts: 684
    I did some groovy math,..
    Based on 1500 gallons of oil burned per year, if you have your burner cleaned, removing 1/16th of an inch of soot you gain 4.5% efficiency, or you save 67.5 gallons of fuel.
    At $3.00 per gallon thats $202.50 Which completely paid for the annual maintenance, and possibly then some. So your saving money as well as having reduced downtime and no heat emergencies from proper filter changes and preventative maintenance.
    its nice to be able to put real numbers on the savings asa marketing tool.
    Thanks Ed!!
  • To Mark & Norm
    To Mark & Norm,
    Glad to help.
    Norm, I have done the same math and you are right on point.
    It is indisputable that a properly adjusted and properly maintained oil heating unit simply saves money for the owner of that oil heating unit.
    Oil heating unit maintenance, done thoroughly and properly, is probably one of the best dollar for dollar investments (Return on investment) that they can make in this economy.
    Regards,
    Ed Carey
