Does a stainless steel chimney liner increase noise?
This summer, I had a stainless steel chimney liner installed for my new gas burner. Now that it is heating season, the noise level is remarkably louder. The rumbling sound emanates from the draft control.
Is this because of the metal chimney liner conducting the sound versus the previous clay liner. When the burner starts, it actually sounds a bit scary with a low pitched rumble, but everything is working correctly and CO is zero.
Steve
