Steamhead, Gordo & Ron Jr.
had probs with "crappy" BI fittings, and things seem to be getting worse.<BR>Out of curiosity what kind of thread dope do you use?<BR><BR>Dave
teflon tape & megaloc easy to clean up safe on plastics I dont get to service steam much though.0 -
Thanks Gerry A ,
I appreciate everyones input.
I LOVE pipefitting but it`s a "bear" with whats out there to work with.
Dave0 -
High Quality Teflon Tape
and high temp RTV silicone! Totally non-traditional, but it works.
Together?
You're using them together?0 -
We use
Teflon tape and paint yellow Rectorseal over the tape . On anything larger than 1 inch ( except steam ) we coat the inner threads of every fitting also . I'll have to agree , the quality if fittings and nipples are going steadily down . But the only area we see leak from time to time is a nipple or male adapter connected directly into a circ flange . It has more to do with paint on the threads of the flange . To fix that we heat it up with the torch and can get almost 2 full turns while it's still hot .
I'd like to know what's been working for people who use larger pipe sizes - 3 inch and over ? We've had problems using the same products and the same methods for the larger sizes .0 -
What order...
Silcone, tape, silicone; tape, silcone; silicone, tape; ?
I've also been having good luck with megaloc. Doesn't do any good for nipples threaded cock eyed, though, which seem to be about half of whats out there. Its too bad, when the Chinese first entered the local market big time, everything was straight and threads looked like they were polished. Now, a year later, they are just as bad as the domestic stuff that was being stocked locally previously.
AARGG!!~!
BoilerproThere was an error rendering this rich post.
Thread Sealant
I use pretty much the same as Ron Jr. I put about five wraps of the thin teflon tape on the male threads and then coat with Rector Seal #5 or Gasoila. Anything over 1 1/4" I coat the female threads per manufacturers instuctions. Cheap insurance for no leaks. Painted or rusted threads I have a fitting brush cut off to fit in my cordless drill and spin it clean. Ron - For large fittings 3" or over "Expando" thread sealant works excellent. It comes as a powder that you actually mix with water and apply with a flux brush or equal. Guaranteed no leaks!!
Darin
- 86.2K THE MAIN WALL
- 52 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 99 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 913 Plumbing
- 6K Radiant Heating
- 380 Solar
- 14.8K Strictly Steam
- 53 Water Quality
- 41 Industry Classes
