Tekmar 071 with the 507?
All of these are 10K NTC (Negative Temperature Coefficient) sensors. At 77F, they register 10,000 ohms resistance. Snowmelt sensors (090) are different just for the record.
I sent you a PDF to your email of the SR503 wiring diagram.
There is a newer sensor available that is for "In-wall" applications that blends fairly nicely. It is a number 084 sensor. Check it out at this link http://www.tekmarcontrols.com/literature/acrobat/d084.pdf
Paul
