tempstick
rjm
rjm Member Posts: 60
Does anyone know of supply house in the Boston area that carries the wax-like crayons used to identify bad traps? (tempsticks?)
  • bigugh_4
    bigugh_4 Member Posts: 405
    You might look
    at supply houses that sell Formica. They bending of that material they use those crayons. I'm in Utah. so cannot help more.
  • Brad White_202
    Brad White_202 Member Posts: 105
    Welding Supply Houses
    Igo's in Watertown carries Tempilsticks and there are other welding supply houses near Southie, all over.
  • mark_120
    mark_120 Member Posts: 6
    Infrared gun is the way to go it will give you more data to work with. You can buy cheap 30 bucks a SEARS or 80-90 at GRAINGER. Plus you can do a lot more troubleshooting with out burning your fingers.
