Now that Kitec has left the bldg...
Derheatmeister
Member Posts: 1,659
So, How about "Siox Chief" Crimp Connectors, what tube are they made for, Do they(Siox Chief) offer tube for these Fittings?
Looking for an alternative PAP that will be compatible with the fittings (same size ID and OD)..
What yuall going to use? Thanks. Heatmeister0 -
My suppliers are looking at Watts, Zurn, and Mr.Pex. Kitec had the best selection of fittings. Maybe the others will step up to the plate.
Dave Stroman, DenverThere was an error rendering this rich post.
kitec
put what fit we had left on shelf for future repairs and change over to veiga pex and fostapex.0 -
Hey Dave,yep the fittings are pretty good..not sure if i should Fill up(Restock) on some of it?( just for repairs/Redos)..
Or like you said some others may step up to the plate
Even better yet have the same OD/ID sizes..
Is Canada maybe the source for Kitec from now on ?
Hope all is well for you down in denver. Richard.0 -
Will Veiga/Fostapex fit the Kitec fittings? Or are they slightly different diameters?
I am Thinking of DIN, where one fits all kinda thing..
( Standard Industries Norms)...Fat chance ehh?0 -
Your in the world of lawyers Pal.
Cover your butt and use only factory approved materials.
I use Veiga tubing and Viega fittings only.
Mix and match is asking for trouble. Which company is going to stand behind you when you have a leak on a Sunday and it takes the cieling down ?
Scott
Same Here
Uponor Pipe / Uponor Fittings..................
Most pex now has the same O.D.0 -
Derheatmeister. Sorry I guess I have been out of the loop. Kitec has left the building? Stopped making in US? or what? I haven't heard anything about Kitec lately.0 -
Discontinued
Ipex/Kitec/WarmRite same thing
Yes they Discontinued the Production and sale for the N. American Heating Market..0 -
Never did like that stuff
Ornery to work with and fittings were proprietary in size and nature.
Viega is still my first choice for PAP. You have to strip the outside coating to accept a sleeve but it uses standard size pex fittings. PAP is great stuff for some applications. I wish they made it in 1-1/4" and 1-1/2" bore. I'd practically do away with the torches.0 -
OK for Certain Situations
Steve,I mainly used it for the transit from CU to the Caleffi Brass manifolds in the mech room...
The nice thing about that is that it keeps its shape once bend into an 90 ....
Never used it > In slab < or > Staple up < I use reg Pex for that.. Richard.0 -
Kitec PAP
Watts' PEX-AL pipe will work with Kitec. No stripping the OD, just fit right on and press...0 -
Standard size, but
not standard fittings! Press SVC, ONLY!0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
