Spec Sheet for Kewanee 7L2905?
I came across(2) Kewanee boilers 7L2905 models 463Hp while doing an energy audit for a residential building in Queens, NY. I am looking for a spec sheet for these boilers, I have attached a pic of the rating plate. Any help would be great! Thanks
  • oil-2-4-6-gas
    oil-2-4-6-gas Member Posts: 641
    what kind of specs are you looking for ? thats a good size boiler ---does this serve as a powerplant for multiple buildings or a 500 family apartment building? if it still has the Kewanee burner on it -when it runs you can make a milk shake on top of it -- you can check with www.burtonmech.com
    they have access to prints, original documents etc....
  • Rich Kontny_3
    Rich Kontny_3 Member Posts: 561
    Kewanee Boilers/Burners
    I was factory trained at the Kewanee Boiler/Burner School in the mid 70s and did a great deal of service on there combination gas/oil commercial boilers. Kewanee has gone into bankruptcy proceedings as of late. There burners at the time were indeed noisy (as were most)yet very reliable and serviceable.
    Kewanee burners were patterned after the Gordon-Piatt burners and are very similar. Webster pumps and other shelf type components were used for these burners. Fire Eye controls were standard.
    I have some manuals stored if they would be of any assistance. Feel free to e-mail me and I can maybe help out!
    Rich
  • don_185
    don_185 Member Posts: 312
    Rich
    Rich,do you have anything on this Kawanee?.....
    Model-KFP-1.5 -762-G Serial # 846341.
    I think the burner model is..m-265-KG.
    I've tried eveything I know of to get the high fire CO down with no luck.
    Thanks in advance.
    To the op..Sorry to jump in on your thread.
  • TwiceFruitful
    TwiceFruitful Member Posts: 2
    > www.burtonmech.com they have access to
    These boilers produce DHW and feed a steam/HW heat x-er for (248) Apts, ~230,630 sf total conditioned space, (32) Floors. The burners have been retrofitted with Johnson FD68 size 400 burners ~8yrs ago.
    I am looking for volume of water these boilers hold in particular...
  • bert
    bert Member Posts: 50
    7L-290
    Steam water volume 2480 gallons
    Water volume (full) 3190 gallons
    hope this helps
