A Cast Iron BB Question
more
Member Posts: 3
I have about 40 feet of cast iron baseboard that I am installing... I'm not sure the brand, it's old and doesn't have any identifying castings on it, it looks a lot like the WM Snug, but the end pieces are different... I had my local heating guy look at it, and he couldn't identify it, but decided to use the specs from WM Snug for heatloss purposes.
Anyways, I have it all apart right now, had it all sandblasted, powdercoated it all, so it's beautiful, finally getting ready to put it back together... I know that there are special tools for snugging the sections back up, but I've been cheating and using long pipe clamps- putting a thin layer of pipe dope on the push nipples and using the pipe clamps (cushioned with wood blocks) to press the sections together... This seems to have worked, I haven't started installing yet, but pressure tested a couple test sections to 30psi... My questions are: Is my method of connecting sufficient? It seems to work, pressure tests fine up to 35psi, but that's just connecting a couple sections together to test... Does anyone have any experience pressing these together without the special tool? Also, I'm planning on piping these in a monoflow loop using the bottom tappings for in and out and plugging the top tappings (with a vent in one) as per my heating guy's instructions... I just wanted to be sure that this is how everyone else would do it... It seems right, but when I bought the baseboard (used) it had been piped to go in the bottom and out the top... Any ideas?
If it works
The tool would have made the work go faster .It does the same job... It is always better to use the top fitting for a supply , but if you can not for what ever reason , you can use the bottom. Using the top distribute the out put more evenly across the sections.There was an error rendering this rich post.
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
