New boiler odor! Help!
Dave_117
Dave_117 Member Posts: 4
I had a new gas steam heat boiler installed yesterday. The odor throughout my home is like heating oil everywhere! AHHHH! My wife is freaking out! Is the smell coming from the radiator steam or from the new boiler or both. Should the boiler be drained and filled several times?
  • It's probably
    oil and grease from cutting and threading pipe. The boiler needs to be flushed and skimmed.
  • David Nadle
    David Nadle Member Posts: 624
    It's oil gassing off the outside of the pipes. It will last a few days and be gone.
  • Ted Robinson
    Ted Robinson Member Posts: 126
    I also experienced "That New Boiler Smell".
    It disappeared fairly quickly.
  • Rich Kontny_3
    Rich Kontny_3 Member Posts: 562
    Always a little
    Oil smell on start up from the residue from machining and threading. Give it some time and you will notice improvement. Hopefully you have enough fresh air for combustion(not an issue with sealed combustion units)Have seen many heat sources with in adequate make-up air.
    Rich
  • Mark Hunt_6
    Mark Hunt_6 Member Posts: 147
    Not unusual
    I've had new boilers set off smoke alarms.
    BUT, that should go away rather quickly. If it persists, contact the installing company.
    Mark H
  • FJL
    FJL Member Posts: 354
    I had a new steam pipe installed . . .
    under my floor to correct a pitch problem, and had a similar odor the first few times that the boiler ran during the start of the heating season. The smell has abated noticeably since then.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,020
    No inside the boiler
    Oil will float on the top of the boiler water. The oil needs to be skimmed off the surface.
  • Big Ed_4
