Why Ditch Gravity?
gasfolk
Member Posts: 392
Folks spend a lot of effort blocking gravity flow in small pipes with flow checks and loops. But in a house with big pipes and an old gravity flow system, adding a pump (the smaller the better) is recommended on the and assumption that gravity flow would be unreliable. Is this contradictory?
Our gravity system was converted (for a time) and first pumped with a 0011 then dropped to an 0010 (both caused a lot of flow noises). But in a 1928 house that has been tightened considerably, why wouldn't gravity flow in the over-sized CI radiation and piping be adequate? Why pump and invite balancing troubles that require addition of TRVs?
If constant circ is the ideal, why can't gravity systems be saved?
gf
gf
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
