Is anyone aware of a thermally actuated 3 or 4 way mixing valve?
Paul Pollets
Member Posts: 3,666
The Oventrop UniBox is a 2 way thermally activated valve with TRV. Mounts on the wall and can handle up to 30K Btu's of output. It's used to pipe a radiant floor zone off a high temp radiator circuit, without having to add an additional low temp mixing device.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=104&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Is anyone aware of a 3 or 4 way thermally actuated mixing valve.. Basically like a TRV but with a wall mount dial and cap tube that actuate the valve.0 -
Danfoss
has a series that might work, depends on size and temperture range0 -
Non-electric
I think Oventrop also makes one.0
- 86.7K THE MAIN WALL
- 54 Biomass
- 101 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 934 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
