BOILER SIZING
![lee_7](https://secure.gravatar.com/avatar/f6560e7888f82022ee81332e99b558bf/?default=https%3A%2F%2Fvanillicon.com%2F9266d888255d22f78d5a4f99d879aecd_200.png&rating=g&size=200)
lee_7
Member Posts: 457
Use the whatever fits down the steps/thru the door method. works great every time
correct sizing methods
There are 3 methods for figuring boiler size. 1st method is the finger method,you stand across the street hold your hand in front of your, face however many fingers it takes to block out the house thats how many sections you need.Now if your still not sure you use the looksalotlike method [no explanation needed].When all else fails you use the swag method which is scientific wild **** guess.Any other methods out there i would enjoy hearing0 -
Another method that Dan mentioned a few years ago in an article is to determine the size of the existing boiler and increase by one size. You'll never get a call back for insufficient heat.0 -
Or...
You could just use the same size that the neighbor has.0
- 86.7K THE MAIN WALL
- 54 Biomass
- 101 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 934 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
