insulation for use in burner are
Steveo_2
Steveo_2 Member Posts: 2
I'm trying to find out what type of insulation the fiber panels are that surround the base on a gas fired boiler. I have an old boiler that the protective insulation panel has deteriorated and the intense heat is starting to damage the boiler jacket. Any help would be appreciated. Thanks.
  • lee_7
    lee_7 Member Posts: 457
    What type of boiler? age? overall condition? pictures?
  • tim smith
    tim smith Member Posts: 2,886
    You should have good burner man put new firepot liner in.
    This would be normal procedure and then analyze combustion. Good luck, Tim
