need help hooking up booter fan to variable speed furnance
don_185
Member Posts: 312
Would that not defeat the purpose as to why you purchase the variable speed motor in the first place?
I think if all possible you would be better off at changing the duct work.
You could add a relay if your t-stat bring on the fan and both heat/cool mode.
IMHO..I think what you are about to do is nothing more then a bandaid.
good luck!
good luck!
no place on control board to have a booster fan come on with blower0 -
Most
VS furnaces power the line voltage to the motor constantly and the electronics tells it when to come on & off.
I would think the furnace would have an EAC terminal putting out 120V anytime the board energizes the blower. Put a relay with a 120V coil on those terminals to turn on & off your booster.0 -
john eac terminal is putting out 120v without energizeing the blower. Thanks For Helping0 -
don finsh basement. ya bandaid. relay will work. thanks0 -
Do you
need only in heating mode? use the HUM (humidifier term).
EAC should only be powered when the blower running. Not a steady 120.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
