tiger loop
Big Ed_4
Big Ed_4 Member Posts: 3,369
A tigerloop let's the air out of the fuel supply line ,or you can say self primes when on one pipe system.
The old way, using a two pipe system . What ever the burner does not burn through the nozzle the pump returns to the tank. And with it air. The problem with this system is what happen when you have a hole in the return oil line ?And you end up trying to clean the tank moving all that oil
So you may want to avoid the old return line. Old oil line with high restriction. Over head lines. One pipe system where the tank is lower them the burner.
  • paul_91
    paul_91 Member Posts: 62
    tiger loop
    can someone explain to me what a tiger loop is...and when should use one?
  • oil-2-4-6-gas
    oil-2-4-6-gas Member Posts: 641
    tigerloops also work well when you have an outdoor tank --the reservoir and extra oil line inside will heat up the oil to a more desirable temperature
