Solar blending in
I like it! No way one can hide them but the installation is neat and true, good proportions. It says that the Owners are thoughtful about it yet it does not overpower the house like some stand-off array might.
That reminds me of the European panels I saw this past summer in Denmark -every house had one or two, just a matter of fact. Little cottages but nearly every one had at least one panel. Not unlike your install.
Yes, that is "brochure worthy" in my opinion!
  • Ron Huber_2
    Ron Huber_2 Member Posts: 127
    Solar Blending In
    Do You think this solar system blends in with the looks of this house? Thinking about using this photo for adds. Do you think it takes away from the look of this house?
  • no blend
    while I don't think it really blends in, it's nevertheless a very neat, clean install. if someone would object to the looks of that then no solar for them.
    edit: you know, on a second look, unless you really look at it you don't really notice it.
    hot_rod Member Posts: 26,649
    Nice
    install and a clean pic to boot.
    A horizontal mount up near the ridge may have blended a bit better.
    The look is second to the primary goal.... a small piece of long lasting energy independence for that family.
    hr
  • Darin Cook_5
    Darin Cook_5 Member Posts: 298
    I like it as well.
    I think it would be great for a company brochure. If only more people would embrace these systems. Everyone has a water heater, it is easy to help folks offset their fossil fuel usage. What kind of systems are you installing and how do you like them?
    Darin
  • Mike C._4
    Mike C._4 Member Posts: 56
    blending in
    To me-those panels blend in as well as anything. Sort of like a chimney. I think people will start to accept them more an more. I have a 120 tube array that had to be tilted up on the front of my house. Because of the oil problems this year I have had more comments on being the "way to go". Even my wife who is picky about "looks" finds them interesting. As an engineer I see the beauty in them and don't care what anyone thinks. I do like watching my hot water recharge for free everyday.
    Mike
  • One thing wrong.....
    Not enough solar panels(G). I love the look of solar. Can't wait till 01/01/09 when the cap comes off for PV!
  • Ron Huber_2
    system types
    We are selling Heliodyne flat plate systems and Viessmann evacuated tubes. Since June we have done 16 Heliodyne systems ranging from 1 to three panel SDHW and one 14 panel heat and SDHW, and six evacuated tube systems, 5 thirty tube systems and one 20 tube.
  • Ron Huber_2
    this enough
    I do not see doing a lot of heating with solar, at least not until oil gets up to $8. Not too many existing homes are really good candidates.This 1980 home was built with passive solar and the roof at 60 degrees for active panels and hot air distribution, these are new Heliodyne panels that we installed to take the place of the panels that where damaged.
  • In Europe we tend to integrate the solar panels into the roof, so that they blend in better
  • Ron Huber_2
    Manufacturer
    Are these panels you install? Who makes them and do they include the flashing kit?
  • kpc_40
    kpc_40 Member Posts: 62
    really...
    no exterior piping to deal w/... esp here in New Hampshire. kpc
  • Ron Huber_2
    esp?
    here in NH. What is esp?
  • kpc_40
    especially
    too use to text messaging w/ my 16 yr. old.
  • Jamie Pompetti_2
    Jamie Pompetti_2 Member Posts: 62
    Ron,
    how did you guys seal your roof penetration in this picture?
    Jamie
  • They are manufactured by Genersys Solar, I did install the systems in the Photo, Genersys solar are now in the USA
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    Hey Ron...
    Nice looking job. I think people are willing to give up some aesthetics in order to incorporate solar, so long as it doesn't look like the Nina, the Pinta and the Santa Maria crossing the horizon...
    BTW, when I was coming home from Hydronicah in Heeney last Sunday, I passed a good looking pickup truck pulling a nice trailer from Ron Huber Construction on I-70 east bound.
    Was that you?
    ME
  • Ron Huber_2
    Not me
    But you may see me on I-90 heading for Livingston Mt.in the near future. Have land there and two daughters and grandchildren there, hope to build and relocate there in the next few years. Land looks over the Yellowstone river and the Rockies are a few miles away.
  • Ron Huber_2
    pipe penetrations
    For this setup, the Viessmann tubes feed and return on the same side, if you want to keep the pipes to a minimum it is hard to separate them and use a conventional boot. I have done this for a long time, drill a hole slightly larger than the pipes, fill in with silicone, top of with roof cement and make a mini pitch pocket, never had a leak this way. For flat plates systems we use "Coolie Caps", it is a copper flashing with pipe flange that seals the penetration and looks good, all you see is the pipe insulation flush with the roof, no ugly boot. The one we use for the top return pipe also has a copper gooseneck for the sensor wire to come out of. I will take a photo of one I have in my work truck tomorrow and will post it.
  • Andrew Hagen_4
    Andrew Hagen_4 Member Posts: 44
    Velux
    Can't say I have first hand knowledge of them, but Velux also makes a collector like this. The collectors match their skylights.
  • Well then...
    Watch your credit rating. You have an imposter :-)
    The Yellowstone valley gig sounds beautiful.
    Enjoy!
    ME
