Dirt Separators on Mod/Con
scott337
Member Posts: 38
Reviewing my GB142 install manual and see that a retrofit requires a dirt separator.
Thinking about this, I think it is a wise idea on ANY mod con boiler with a narrow/tight heat exchanger (Alpine/Freedom/Ultra/Munchkin/Knight, Triangle Tube, etc)
I did some research and bought a Spirotrap Dirt Eliminator, works GREAT!
Never knew these mod/con's were so sensitive to dirt but certainly grasp the issue at hand. Dirt can plug these boilers rather quick or easy and then we will be left holding the bag because we didn't install it according to the manual....
Thought you guys may want a nickles worth of advice:
Install one of these on ALL mod/con jobs and save the hassle of a potential problem.....
- 120.3K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 31 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 152 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 737 Plumbing
- 5.2K Radiant Heating
- 357 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 36 Industry Classes
- 70 Job Opportunities
- 14 Recall Announcements
