Sand over radiant?
Big Ed_4
Member Posts: 3,240
Do you find radiant heat wood floor tadder the wood over time.
Sand Over Radiant?
I have a customer who wants to put an 1-1/2" layer of sand in between the sleepers over the top of my tubing. Customer does not want gypcrete. They are putting 3/4" wood flooring over the top. Any ideas on reccomended installation of the sand. Does it need felt paper over the top? What kind of sand? Any ideas would be of great help!
Luke
Rocky Mntn Plg. & Htg.0 -
Dry sand does not conduct heat very well.I had a customer do this some years back and it worked but supply temps are kinda high. You also have to consider pipe expansion.
I never did this but with Geothermal the best conductor is clay I always wanted to try it with radiant. I think it would work great and compacted it would help with expansion.
Mike A0 -
It's a mess
and it doesnt work very well. You also have to very careful not to get sand in between pieces of wood where it can make noises. There are better options. Those options depend on the heat loss. If the heat loss is low you could just leave air space. If it's high use plates. Watts Htwy suggests putting flashing on top of the sub floor, and in under the hardwood, to spread the heat and have the tubing touching the sub floor from beneath. I havent done that yet but it makes sense to me. Good luck. WW
at least add some portland to it
dry sand is a poor conductor, has terrible consolidation, and has been know to harbor bugs. especially when warmed
If the wood is not in contact with the sand you lose the best heat transfer, conduction!
It may work to some degree under concrete where it touches the emitter (slab)
Adding some cement to the sand would keep it where you want it, increase the heat transfer from the tube and into the flooring where you want the heat.
hrBob "hot rod" Rohr
Living the hydronic dream0 -
Does
pea gravel or some similar small rock or stone product trasfer heat ? I think I saw a Bob Vila show where they had a rock floor in a sun room that picked up alot of heat from the sun and released it at night . Thinking about it , not the best choice if the tubing rubs against the rocks while expanding and contracting .
Levittown was built with radiant pipe sandwiched between sand and concrete . Mostly in the upper layer of sand though , with no insulation underneath . But it worked great ...... while they lasted .0 -
Sandwich
How about 3/4" rigid foam between them, then tubing and subfloor. I have done this with onyx and it worked well.0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 984 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
