What size oil steam boiler is needed for a total EDR 60,000?
klaus
Member Posts: 183
Unless you're also switching to gas?
If so you can't beat W/M's 3" risers on the EG-line. If oil is it, the Burnham is best.
I am replacing an Oil steam boiler. My total EDR is 60,000 for all radiators in the house. Is a Weil-McLain SGO-3 model with an I B R Steam 354 Sq Ft ok for this installation. It is the smallest steam boiler they offer.0 -
That would equal 250 square feet EDR
must be a pretty small house. For that load I'd go with the Burnham MegaSteam 288. It's a much better match for this load- 288 square feet as opposed to 354- and is more efficient and easier to service as well.
Ditto
I agree 100% with steamhead, go with the Burnham Meagasteam, it is in a class all by itself. The MST288 would be perfect for your application and much more efficient than a SGO30 -
WM Oil Steam
Brent,
The SGO is an oil fired, cast iron wet base, steam.
Are you also using the boiler for your domestic hot water with a tankless or indirect?
If so, the contractor may be allowing the additional load for your DHW requirements.
Also, I agree, you would love that Burnham Megasteam if you got it.
JMHO
Ed Carey0 -
Or for a boiler that can burn either oil or gas
try the Smith 8 series, called the G-8 when set up for gas. Here's one we just installed, with the gas burner, and the piping changed around a bit to re-use some existing 4-inch pipe in the header.
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
