Electric Steam boiler residential
Carlton_2
Member Posts: 1
Dan,
I looking to buy an Electric Steam boiler, I'm replacing my combi oil boiler. I'm using tankless for the Hot Water. I've research and found 2 companies which have the Electric Steam boiler. I'm wondering if I could tap your resourse of knowledge. From the excerpt of your book(Yes, I will be buying) you already showed me about the air in the line, and the Main air valves still in place.
So, I'm looking to get an boiler rated @ 72KW, @ 220lb/hr. The old boiler was 216lb/hr. Single pipe system.
I've contacted ServiceMagic and other contrators with no results, the Electric Steam scares them.
Not interrested in any compromise that has Gas or Oil in the process.
Any help is greatly appreciated
Carlton
Carlton
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
