condensate discharge tube
Timco
Member Posts: 3,040
What type of tubing is rated to be installed in a ceiling that will be sheetrocked in a year or so? I have to run it 70' to a laundry area to drain it...
Tim
Tim
We use a chemical tubing found at our "Tractor Supply Company" store nearby. It comes in 25', 50' and 100' rolls. It is much heavier then stuff at local hvac supply house and doesn't kink as easy.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
