triple aquastat
paul_91
Member Posts: 62
can anyone explain to me how a triple aquastat operates with other circulators , using ra845a relays?....confused..
Are you maintaining Boiler temperature? If you are connect you others as if it's not there. If your only firing the boiler on a call for heat then take the circulator out of the triple and use a multi zone control or seperate controls with end switches wired back to the T T of the triple. Option 2 use zone valves and one circulator off the Triple aquastat with the end switched to the T T.
Note: If you don't want to maintain boiler temperature disconect the blue wire from the terminal inside the triple aquastat.
not sure that this is what you want
but it oughta be of some use. See page 8
- 86.7K THE MAIN WALL
- 54 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 67 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
