Pex tubing installed in hot water heat
Rick_86
Member Posts: 19
Is O2 barrier, oxygen barrier etc. listed anywhere on the pipe? What are the markings? Pex manufacturers put all kinds of information on their tubing. Before you panic read what's on the pipe...
I recently pruchased a house that has hot water heat. The system was drained and some work was done by the previous owner. Some pex was installed in the floor for a heat and also to one radiator. I see that there are differnet pex pipes for heating systems. If the wrong pipe was used is there anything I can do to help prevent corrosion other than tearing everything apart and replacing the pipe? I can not access any of it. It may be a false alarm, but I don't want to take any chances. I estimate theres about 60ft. of pex installed. Any help would be great.0 -
I tried, but theres only a little stub sticking out of the wall on either side of the radiator. I really can see anything, all other pex is inside the floor. Do I have any options if it is aqua pex? Like additives for corrosion control?0 -
Thanks for the link it was very useful. Can you recommend any chemicals I could use even if its just a precaution? Maybe it will help me sleep better at night until I can change the tubing if it is not the right stuff.
Thanks again0 -
Jason, can you post a picture of the pipe you are talking about? We may be able to identify it from the picture.There was an error rendering this rich post.
- 86.7K THE MAIN WALL
- 54 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 67 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
