Insulation Fillers
Thanks David - I probably also should have mentioned it was for steam and is linked with an ancient piping system with lots of weird angles.
Insulation Fillers
Insulation wise, what is the best product to use to fill in the spaces between formed fiberglass pipe insulation?.... like in the areas around tees, elbows, fittings etc. Is there some "putty like" product that is moldable?
I don't know if they're the best, but I think the easiest is the PVC fitting covers. They come with matching fiberglass blankets and they come sized to your insulation o.d.
I assumed you meant steam. The PVC fittings come in 45°, 90° and tee.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 5.7K Gas Heating
- 110 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 996 Plumbing
- 6.3K Radiant Heating
- 391 Solar
- 15.4K Strictly Steam
- 55 Water Quality
- 44 Industry Classes
- 48 Job Opportunities
