Hoffman #55 F&T
Jack_44
Member Posts: 35
it was State Supply that sold me Hoffman kits for 55 & 53 a couple of years ago. Quick fix.
Can this trap be cleaned, or is there a rebuild kit for it? I have one that was sticking, and when I tapped on it the trap closed quickly...
Thanks, TimJust a guy running some pipes.0 -
What does Tunstall
have to say?0 -
the last 55 i dealt with was a 2" and i had to "fashion"( i brazed,drilled out some brass misc. fittings to make a new seat and plunger for it at midnight) seat was broken blowing steam everywhere-- anyway yes they do sell rebuild kits for them Barnes nd Jones or of course Tunstal --if needed take apart and clean out - seal the gasket for now with high temp silicone -you will need to clean the -y-strainer before it -or install 1 if here is none0 -
Tunstall all the way!
You need to talk to Woody Tustall at Tunstall, Inc. Awesome company to deal with. Very catering company. www.Tunstall-inc.com. You need kit# 5FP-HF-15, I belive. Good Luck!
Ross0 -
Thanks again, fellas! Life goes on...
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
