Splitting Radiators
Paul_58
Member Posts: 18
I may attempt to reduce a thin-tube style radiator from 16 to 8 sections. I assume I will need both end sections when I reconstruct the radiator. Is this correct? Thanks.
Splitting Radiators
I may attempt to reduce a thin-tube style radiator from 16 to 8 sections. I assume I will need both end sections when I reconstruct the radiator. Is this correct? Thanks.0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 67 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
